1000 RR8 Fireblade headers to 919 RRW Streetfighter
Discussion in 'Mechanical' started by megawatt, Feb 27, 2012.
  1. megawatt
    I am planning on doing a lot of mods to silencers and my RRW exhaust system in the near future. So I thought I'd buy a set of RR8 headers and try to modify them to fit my RRW. Why RR8 you may ask, well the main reason was price. A set of RRW stainless headers went on eBay last night for £122 plus postage. I bought these RR8 headers last week for £4.49 plus £10 postage :D:D:D
    The RR8 headers are 38mm o/d and lighter than RRW headers.A few dimensions are similar and a few very different;
    Collars to fit to head are almost the same. Brackets to clamp headers to head are the same. Spacing between cylinders are very similar, about 2mm difference . Main difference apart from bends and shape of headers is that RR8 are 45 mm shorter in the vertical section, ie they will foul the sump unless I extend the verticals.
    A few pix;
    RRW headers
    RR8 headers
    I marked the vertical section of the headers 150mm from the collars and started cutting the tops off.
    This is no4 header top section.
    Will do a bit more tomorrow before work.:D:D:D
    Ducky likes this.
  2. megawatt
    Managed to cut and file the other three stubs and fit em to the RRW engine this morning;
    The view from underneath;
    Next job is to make a bracket to support the RR8 exhaust in the best position while I make and fit the 38mm spacers into the gaps!
    Mind you I could just stick with the stubby headers??? Double click on the piccy?
    deano81 likes this.
  3. Ducky
    I started my duc in the garage once with no pipes fitted, bloomin blew my eardrums! lol
  4. hoppielimp
    Could be abit loud...???? :noway: Looks very cool..though you might get loads of crap all over your engine in the longer run...
    PS. I had my Computer speakers turned down...:D
  5. megawatt
    Guess I,d better weld the tubes on to join em to the manifold then?
  6. hoppielimp
    u could modify a scottoiler or something to drip oil into the exhaust, so you can press a button and create a smoke screen...this is sort of a tangent to Range Rover drivers ... which you could use the said modification on them....:rolleyes:
