Electrical/alarm Issues On A Street Triple
Discussion in 'Mechanical' started by Jon Weston, Mar 12, 2017.
  1. Jon Weston
    Jon Weston Moderator Staff Member Moderator + Site Supporter
    I've had issues in the past with bad contact in the kill switch, and similar issues happened this morning resulting in failure to start. There was some crud on the contacts which was cleaned off but the bastered still didn't start.
    Noticed some random clicking coming from the alarm and that the light on the dash wasn't flashing as normal. It's serial number is not on the recall list but having my doubts now.
    Here are some vids if anyone notices anything familiar or can offer some advice:
    Alarm light flashing when ignition on and disarmed (does not usually do this) -
    Arming and disarming the alarm -
    Cheers for any advice, Jon
  2. Beelady
    Beelady Custom cruiser +
    Try a visit to the Street Triple Forum. Just about everything you might want to know about Striples is on there. Friendly, too. Sorry I don't know how to do a link but it comes up on Google.
  3. BlackHornet
    do you have a master key with the bike ?
    Be worth checking that just to make sure the code hasn't dropped off
  4. MaDProFF
    MaDProFF British Superbike +
    675.cc forum shed loads know everything too about Streets
  5. Mikey
    Mikey Sport Tourer +
    If you had bought cake back, it might not have happened that's all I'm saying lol
  6. MaDProFF
    Silly ? Is battery flat? I know you boight a new one last year, but when u last use it?
  7. Jon Weston
    It's on an optimiser - but will double check its not borked
  8. Jon Weston
    Was advised on a dedicated Street Triple forum to get a 'shorting plug' from Triumph to disconnect and disable the alarm from the ECU.
    Got one and fitted it and started first time, and then every time after! Reconnected the alarm and everything went wonky again. Definitely an alarm issue. Will get onto Datatool to get some advice.
    Have been out for a nice ride in the spring sunshine - lovely! :sun1:
  9. MaDProFF
    dam cold and windy more like :( just get a new bike :p
    Jon Weston likes this.
  10. Roadwart
    Nice to know you may be getting somewhere Jon. :thumbsup:
