HELP ME! ANY1 HAVE AN ENGINE PRESSURE GAUGE?
Discussion in 'Mechanical' started by Emma - 125cc Marauder, Feb 11, 2012.
  1. Emma - 125cc Marauder
    Emma - 125cc Marauder Off Roader +
    Bloody snow, not only does the stuff ruin a perfectly good ride but it plays havoc with oil systems too... gggrrrr.CAN ANYONE PLEASE HELP ...i need an engine prussure gauge does neone have one that i can borrow its URGANT :) thanks xx
  2. megawatt
    I don;t ,but do you mean summat to put in a plughole to check compression? What's up?
  3. Emma - 125cc Marauder
    Yeah thats it, f..king thing, its got mayonnise for oil and i have a hoorible feeling it wont just be a new filter i need :(
  4. megawatt
    Drain the oil and have a look at it then. Is your bike air or liquid cooled?
  5. Emma - 125cc Marauder
    thats the thing its just air cooled
  6. Skortchio
    It shouldn't play havoc with oil systems, as the pour point of Grade 3 oils (most bike oil) is about -10°
    As Mega says, do you mean a compression tester or an oil pressure gauge. If you mean oil pressue gauge you have a light that shows when its too low, if you want an indipendant gauge you'll need a take off pipe fitted to the sump.
    What's the problem?
  7. megawatt
    Probably just condensation then! Get engine warm, in a warm garage preferably, drain oil out and leave moisture to evaporate. Don't forget to put drain plug and oil back in though, or replace oil with fresh stuff?
  8. Skortchio
    Dammit, replies while I replied.
    Chances are its just a little emulsifiying due to the cold, condensation forms in the pathways and causes the milky looking deposits. A healthy blast will evaporate the water and clear it up. If the whole of the oil is milky its a headgasket indicator.
  9. Emma - 125cc Marauder
    Thank you guys that confirms my bf suspitions, i was panicing it might be the gasket lol :)
  10. Jim
    Jim Race Rep +
    Yeah, what he said! :yright:
    Skortchio and Roadwart like this.
  11. megawatt
    That's what happens when you don't ride it enough?
  12. Emma - 125cc Marauder
    Speak for yourself, that thing is on the road everyday regardless of the weather
    Sporty1200 likes this.
  13. megawatt
    Hmmm, wonder how it got condensation in it then. Is it parked outside?
  14. Skortchio
    Hot engine, cold atmosphere. Same way condensation usually forms :p
  15. Emma - 125cc Marauder
    It is and although im ashamed to admit it , it rarely gets covered,,it was a snow sculpture on monday :(
