Exhaust coating to prevent rust.
Discussion in 'Mechanical' started by ShootBob, Sep 10, 2012.
  1. ShootBob
    ShootBob Learner
    Hi all, the exhaust on my Bandit has rusted away at the point where the front and rear join. I have a replacement rear pipe and was wondering if there is anything i can coat it with to prevent it going the same way. Would red oxide paint be suitable? Any suggestions welcome! Ta.
  2. megawatt
    The best fix is to replace mild steel with stainless or Titanium. If you must stick with mild steel, paint it with barbecue paint, regularly.
  3. ShootBob
    ShootBob Learner
    Barbecue paint? I shall look it up. I am going to get the old pipe re welded with stainless. Apart from the mild steel part its immaculate! Thanks for the advice. :thumbsup:
  4. megawatt
    There,s loads of other special paints, none of em work. How much you paying for weld repair?
  5. ShootBob
    ShootBob Learner
    I haven't looked into it yet. Any thoughts?
  6. megawatt
    Would be interested in what you get quoted, and I,ll probably be able to beat it.
  7. SpiritofFreedom
    SpiritofFreedom Moped +
    Can you TiG weld??? If I decides to keep my YZF, I might want to spend a few quids to get some mods done to the alloy swingarm.
  8. megawatt
    I do the fabrication and get a professional welder to do the welding.
  9. SpiritofFreedom
    But would like it to look like this with fabricated alloy plates welded in the gaps untitled - Copy.png
    Is it possible & what's the damage???
  10. megawatt
    Yes it is possible and I have no idea how much. Need to have a look at it ?
  11. SpiritofFreedom
    So have you any idea on cost yet mega?
  12. megawatt
    Pm yer number for a chat mate..?
  13. SpiritofFreedom
    Will do once I've worked out how to do that :eek:
  14. megawatt
    Have sent you a PM mate, just bell me or reply to it:)
  15. Skortchio
    There's no point mixing mild and stainless on the same pipework. If 90% of it's mild then a tiny corrosion resistant patch makes little to no sense.
    BBQ paint isn't up to the rigours of 80mph spray and dirt being flung at it and the heat build up is far higher on an exhaust, you'll be recoating it every week. I used higer temp paint on the Mini exhaust and it lasted all of about 25minutes.
    Best coating for exhaust pipes is ceramic, it's not overly expensive and it's treat and forget. Plus you can have it in a range of crazy colours ;)
    Your ally plates shouldn't cost you more than 2hours work, unless you want them to brush finish the ally too. It's simple shapes and easy to access. Don't know what the going rates are down south and the aerospace guy I use is a friend so my idea of costs are probably a tad on the low side :laugh:
  16. SpiritofFreedom
    Ah.....aerospace. Now there's a thought. Forgotten so much! I should of kept in contact with the people I worked with in this industry!
