Square Bolt Help/advice
Discussion in 'Mechanical' started by NAPA121, Jul 22, 2016.
  1. NAPA121
    NAPA121 Secret prototype +
    Guys,
    Normally you buy a U bolt, C bolt, Square bolt for a trailer and drill holes to fit.
    Problem is i already have a load of holes in my trailer and ideally would like to find 3 square bolts with an M8 thread which are exactly 110mm inside diameter from the centre of the bolt thread at either end.
    Does anyone know somewhere that will do this?
    Cheers
    Neil
  2. hoppielimp
    erm....can't quite figure out exactly what you are after...its the 110mm inside diameter thats thrown me... :thumbsdown:
  3. BlackHornet
    Do you have a picture? That size sounds like a fencing bolt so maybe avs?
  4. NAPA121
    This is the sort of thing I am after but it must measure 110mm from centre of thread to the other centre of thread.
    lisa lou likes this.
  5. BlackHornet
    Ah then nope. Bar treaded rod and welding a nut on no idea on where to find that.
  6. phil read
    phil read World Superbike +
    You'll probably have to make it shouldn't be to difficult, could you not use lengths of flat steel with 8mm holes at 110mm centres then a couple of 8mm bolts & nuts
    megawatt likes this.
  7. NAPA121
    lol.....:hah::hah::hah::hah::hah::hah::hah::hah::hah::hah::hah::hah::hah:
    Do you know who you are talking to Phil? I struggle to make a paper airplane.
    megawatt, Beelady and phil read like this.
  8. phil read
    I'm away for A few weeks if your not sorted when I get back we'll knock something up.
    NAPA121 likes this.
  9. phil read
    Google square u bolt/clamp
  10. Miky_G
    Miky_G World Superbike +
    You need a 'Tony' !
  11. Fergy
    Fergy Secret prototype +
    Alternative question would be... what are you trying to do with it?
  12. Mikey
    Mikey Street Fighter +
    Threaded bar and bend your own to fit :whistle:
    NAPA121 likes this.
  13. hoppielimp
    NAPA121 likes this.
  14. Garya
    Garya World Superbike +
    Have you tried a trailer company
    NAPA121 likes this.
  15. NAPA121
    yes tried a trailer company and will need to get them manufactured :-(
    Weighing up my options.. Hopefully Phil Read might be able to help when he gets back.....
    Anyone know when that will be?
  16. GuzziRob
    Talk to a local Blacksmith?
  17. phil read
    Back on Sunday the 14/8 sometime after that if you've not got it sorted
  18. NAPA121
    Ok thanks Phil.
    I think I am ok now as needed to get sorted for Friday's trip to Bedford.
    Basically i used Eye Bolts (didn't even know they existed) that go into one hole so have used two on each hole. I think they should be strong enough but do let me know if you think they wont be.
    Also, I have ordered a piece of Galvanised Steel Angle Iron that I will attach to the underside of each ramp so that I can then put another couple of eye bolts in the middle so the rear tyre down can hook down in-between both bikes.
    Once complete i will post a picture but hopefully that sounds ok?
    I'll soon find out when I get to bedford with or without two bikes....
