Indicator flash rates
Discussion in 'Mechanical' started by Hanna, Sep 2, 2012.
  1. GuzziRob
  2. Ducky
    They do an led indicator option :) but Hanna has a different style of indicator.
  3. GuzziRob
    Like these?
  4. Hanna
    Hanna Street Fighter +
    You can see on the electrical tape where the resistor got hot and melted against it - which makes me think the resistor has blown?
    The indicators were made specifically for this bike. They are made to order by Watsen Design who are well regarded, so I would not expect them to have used the wrong resistor. For note I've got them on both the front and back of the bike.
  5. Ducky
    I would have expected a resistor with a heat sink, but then perhaps m/c indicators use lower wattage bulbs compared to cars, you could test the resistor with a multimeter if you have one. :)
  6. Skortchio
    They're all the same, 12v 5watt as standard (bar the usual odd exceptions posibly including the S1000R).
    Resistor with heat sink is the way forward though, from the pic it looks like the heatshrink has melted from the outside possibly laying against the resistor. The wire itself isn't damaged is it? Can't see clearly.
    Given they were made to order, it's possible that Watsen aren't completely familiar with the BMW and it's novel wiring.
    If they're flashing too fast only with the engine on then the resistors aren't resisting enough.
  7. BlackHornet
    please all bow to me for being right first :ner::ner::ner:
    i'm getting good at this :D
    next i will be able to tell you your tyre pressure just by the thumb test, what do you recon JimG is that possible :p
  8. Skortchio
    :respekt: (couldn't find a bow)
  9. megawatt
    Welcome back Dave, where ya been?;)
  10. Skortchio
    Hello fella.
    Hospital, stomach bug (some timing) lots and lots of painting, bit of welding and... erm.. yeah, that's about all. Nearly done now though!
    Ogy is looking a tad different ;)
  11. megawatt
    Don't be stranger;)
  12. Skortchio
    Can't help it, strange is all I know.
  13. Les
    Progress? Don' fink so.
    kitten_art likes this.
  14. SpiritofFreedom
    SpiritofFreedom Moped +
    May need to take it to BMW dealer to have the bike plugged in & reset. As I've said. There a many different signals running through these sames wires. Only BMW will know which signal will tell which peripheral component what to do. If the wrong signal get to these components then............
  15. deano81
    hard to guage the size from the pic but that looks like a 1W 33 ohm resistor... are the indicators bulb or led's?
    il have a nose in the workshop tomorow pretty sure ive got some 5w power resistors kicking around will check the values..
